Instant Replay
Disable access from VMIX to Contour Pro
Joined: 3/19/2017(UTC) Posts: 15 Location: Canary islands, ES
Might sound weird, but.. how do i tell Vmix to ignore the Contour Pro? I'm using a contour to handle another software, but Vmix keeps listening to the commands send by the USB device. I can disable the shortcuts, but I can't find a way to disable the jpg/shuttle from playing havoc with my replays.
Under shortcuts, Midi Devices > untick the Contour Pro and any shortcuts that are bound may also need to be disabled. Pretty sure that will work but don't use the Contour Pro but have a few different Midi controllers that I use in the production.
corporatejames wrote:Under shortcuts, Midi Devices > untick the Contour Pro and any shortcuts that are bound may also need to be disabled. Pretty sure that will work but don't use the Contour Pro but have a few different Midi controllers that I use in the production. Like i said, i can disable the shortcuts, but the jog/shuttle is directly configured, no shortcuts.
@ nachojimenez
Does it make a difference if you plug in the device after you launch vMix? I find it works that way with MIDI devices but I am not sure about the Contour Shuttle Pro.
IceStream wrote:@ nachojimenez
Ice I needed to control other things with it, could not do that. I finally unpluged it, and hacked and old Newtek Timewarp controller that also has a jog/shuttle so i could control the replays and the playlists with the same item via scripts.
Instant Replay
