Feature Requests
API for VLC STREAM (RTMP/RTSP...)
Dear Mr vMix. I would like the possibility to add VLC RTMP/RTSP source with the API and define buffer if it's possible. like this : http://127.0.0.1:8088/API/?Function=AddInput&Value=VLC|rtmp://192.168.1.50/stream|5000 result : Add a VLC RTMP source and set the buffer to 5000 ms Thanks for all. Best regards.
+1 to this. We have a bloom of internal multicast udp streams I would like to be able to switch between as inputs.
Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
Any news about option to add rtmp via API?
Is there any other way to have dynamic RTMP to vMix?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Might want to check the shortcuts (of output v23)
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
+1 for extending the api to add VLC rtsp streams incl. custom buffer. And if possible also changing an already existing input to a VLC source.
Feature Requests
