epicenter800
#1 Posted : Tuesday, October 3, 2017 10:02:25 AM(UTC)
epicenter800
Hello all!
I am using vMix 20 4k with an nVidia GT750m GPU. I am unable to select any other option other than "output" on Display 1. I am able to select other options on my Display 2.
Any ideas?
Thanks in advance.
#2 Posted : Tuesday, October 3, 2017 1:39:35 PM(UTC)
Was thanked: 795 time(s) in 589 post(s)
Hi
Make sure you have correctly set up your displays in settings
https://www.vmix.com/help20/Display.html
Check also the Outputs/NDI settings here : https://www.vmix.com/help20/SettingsOutputs.html
I'm am quite sure you only forgot to activate your displays
Guillaume
