Problems using my computer on board audio since 20.0.0.30
Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
Good day Martin and the team, since the recent update to 20.0.0.30 im having issues with using the computer on board sound device. I am using the blackmagic quad card to input video from three sony pxw x70 cameras, i dont use the embedded audio from the SDI signal, i have a separate sound board which i use to input audio and select when setting up the cameras inputs. Now when i select Decklink SDI 1 and go to Audio input that option is no longer there i'm now seeing embedded 12,34,56,78, Allchannels no option to select my computer sound port. Is there something im missing and how do i use my on board audio. Legacy settings dont work.
Using a HP Elitedesk Tower, never had an issue until now.
Regards
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
When adding a camera, the audio options should only ever be used with the matching audio for that particular camera input. It was never intended to be used with other devices, which is why we have slowly moved towards implementing SDKs for the camera inputs so that their audio no longer needs to be selected. (this began around vMix 17 onwards)
Instead, the separate audio should always be added via Add Input -> Audio Input.
If then you would like this input to automatically follow the camera input, simply enable the automatic audio mixing in the input settings and then assign it to one of the 10 multiview layers for the camera input.
Martin vMix
