Feature Requests
Replay: Ability to update selected angles for clip while playing
Hi vMixers,
I propose the feature and ability to update the selected angles for a clip while playing. This is feature that I've needed in several occasions where I played out a clip of 10 seconds. Initially it were set only to playback on camera1, but during playback, I figured that I really wanted it also to be played out on e.g. cam 2. I have set up shortcuts to enable the additional angles, but the playback of the replay does not automatically pick up on the change while playing, meaning that the clip will only play the original selected angles to finish.
The request is therefore in the module to pick up of events setting angles on the clip currently playing, allowing updates for angles.
Best regards Jens Stigaard
stigaard wrote:Hi vMixers,
Best regards Jens Stigaard +1
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Joined: 9/9/2017(UTC) Posts: 36  Location: Jeffry_Ghost Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
Feature Requests
