How to Save XAML title as DLL
Hello. I have a title I made in Microsoft Blend. At the first testing I found out that for this title it is necessary to connect the managed block.
The managed block works well with the .dll file. Can anyone knows how to save Xaml as .DLL?
Or can someone tell me how to hook the trigger to a certain object that can be changed in vMix, and depending on the data it includes different triggers
Joined: 12/27/2012(UTC) Posts: 5,474  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Maybe a lot is lost in translation as I don't fully understand the questions or your goal but there are a few code examples in this forum regarding xaml titles saved as .dll due to the codebehind needed to achieve certain goals . I believe they are rather called wpf control librarys in blend which end up as .dll when compiled
They might help you along
doggy wrote:Maybe a lot is lost in translation as I don't fully understand the questions or your goal but there are a few code examples in this forum regarding xaml titles saved as .dll due to the codebehind needed to achieve certain goals . I believe they are rather called wpf control librarys in blend which end up as .dll when compiled
They might help you along My goal is for this image to be in the .dll file with all the animation
You really need to be more specific as plain xaml files can handle the graphics and animations (start and end output) and changing the text by edit on its own
