LiveMix
#1 Posted : Friday, September 22, 2017 3:59:49 PM(UTC)
LiveMix
I installed vMix 20.0.0.27 and im trying broadcasting with my account instagram.
i can't find the way, i know instagram doesn't support Stream Key for streaming, so can i do it by vMix and how ?
Thank you
#2 Posted : Friday, September 22, 2017 5:10:57 PM(UTC)
hi
I'm not aware of a possible solution for this. So far Instagram only allows to stream from a smartphone webcam AFAIK.
Guillaume
Ittaidv
#3 Posted : Friday, September 22, 2017 6:49:54 PM(UTC)
Ittaidv
If you have an android compatible uvc hdmi grabber, you could try it by using an android tv box and using the hdmi grabber as the camera to stream your content. Works well with some android only apps, never tried it with instagram though.
corporatejames
#4 Posted : Thursday, November 16, 2017 4:04:18 PM(UTC)
corporatejames
You can livestream to Instagram using the Windows 10 Instagram app and a web cam so maybe could feed Vmix output back through to the app? They also have their API available now that has rtmp code so maybe Vmix could integrate it? They don't have a stream key from sample api code that I could see and looks that it users your login so would to have your Instragram account details.
