wilcoxk
#1 Posted : Wednesday, September 20, 2017 11:18:28 AM(UTC)
wilcoxk
As stated in the title, we have a video added as an input. When we switch to that input, it skips the first 5 seconds and the continues playing the rest. Any ideas? I see there are in and out points and I have reset these.
kjones9999
#2 Posted: : Wednesday, September 20, 2017 8:47:30 PM(UTC)
kjones9999
Could be a corrupted header. I would convert to mpeg2 and see if it is still there....
raugert
#3 Posted : Wednesday, September 20, 2017 9:38:50 PM(UTC)
raugert
Canada
I have the same issue using an external drive on USB3. I always attributed that problem to being an external source. Are you using one by any chance ?
stigaard
#4 Posted : Thursday, September 21, 2017 1:23:52 AM(UTC)
stigaard
Denmark
I actually saw similar problem once, but I can't remember if the video file were located on a external drive..
Have you guys verified that the solution were simply to put it to a local drive?
#5 Posted : Thursday, September 21, 2017 4:30:35 AM(UTC)
I guess it's incorrect keyframe in this video.
Try re-indexing it and make sure you have keyframes every 2 seconds for example and especially one on the very first frame.
Guillaume
stigaard on 9/21/2017(UTC)
wilcoxk
#6 Posted : Thursday, September 21, 2017 8:51:49 AM(UTC)
wilcoxk
Oh, You know what? The video might have been on a USB flash drive. I'll check that.
Not sure what keyframes are but I suspect if I Google it, I'll find something.
And the idea of converting to MPEG2...... I guess I would use handbrake for that?....
wilcoxk
#7 Posted : Thursday, September 21, 2017 9:29:44 AM(UTC)
wilcoxk
I moved the video to the local disk. The first time I played it back, it worked, but each time after that it still skips about 5 seconds. I converted to mpeg-2, but it looks like that reduced the quality. I haven't gotten to test if the issue persists with mpeg-2.
wilcoxk
#8 Posted : Thursday, September 21, 2017 12:28:17 PM(UTC)
wilcoxk
Even with Mpeg-2 it seems to have a problem.
I removed .mp4 from the list of formats that playback with FFMPEG and that fixed it. Any ideas on why this would be the case?
