Broachbilly
#1 Posted : Saturday, September 16, 2017 3:11:34 AM(UTC)
Broachbilly
Hello.
We tried using the NDI capture this past Sunday.
Worked great. Until The PC Rebooted during P&W.
Got the computer back up Loaded NDI Loaded Pro Presenter worked fine for a few minutes. Rebooted.
Did it again.
Rebooted the computer did not load NDI Capture. Loaded Pro Presenter and continued with church service.
After the sermon and after ending prayers .. Loaded NDI Capture and loaded announcement video.
Yep... Rebooted...
Yes. new version of NDI.
Windows 10 with updates.
kane
#2 Posted : Saturday, September 16, 2017 10:14:36 AM(UTC)
kane
ProPresenter does have a NDI output module, then you don't have to use any external NDI screen capture tool.
https://renewedvision.com/propresenter/modules/
Otherwise, there are other NDI Screen Capture tools. NewTek's NDI Scan Converter or OBS Studio with the NDI plugin are both free.
Kane Peterson
NewTek
Broachbilly
#3 Posted : Tuesday, September 19, 2017 12:44:52 AM(UTC)
Broachbilly
the first go round I used VMix NDI. today I installed NewTek's NDI Scan Converter.
Worked great until I loaded ProPresenter. and Yes. Rebooted..
Will have to go through channels to purchase Propresenter NDI Module for $99.... Why I don't like PP. all the extra cost for modules..
