fs2com
#1 Posted : Friday, January 11, 2013 1:40:30 PM(UTC)
fs2com
Hi Martin,
First of all I wanna thank you for this wonderful software. Just found out and play a bit with it.
I think I found a bug with the right click menu pop up. (Tried with v5 and v8)
Here's what I did...
1. Add input, Title, TickerHD
2. on Title Editor I click Preset plus sign to make it 1 or more entry
3. Now if you try to right click on the TickerHD.xaml the menu will show up on the full screen display monitor not on the editor/mixer display. And if you click Title Editor the Title Editor window will show up on the full screen monitor too, so I had to drag it to my editor display.
but if i add TickerHD and just click ok (not clicking plus sign) this bug doesn't occur... the menu pop up on the correct display.
One other thing I noticed is the pop up menu is stretching so long because it contained all the text on the TickerHD.
Hopefully my explanation is not to confusing.
Best Regards,
Ferry
fs2com
#2 Posted : Saturday, January 12, 2013 12:48:35 PM(UTC)
fs2com
Today I test on my other computer (older one).. the problem doesn't appear on that computer...
both setup using win 7 64bit the differences is the older one using dual core/intel p31 chipset/nvidia graphic card/2 lcd monitor (square one)
the new and had problem using core i5/intel z68 chipset/ati graphic card/1 wide lcd monitor and 1 samsung led tv
I don't know which combination trigger the bug... but i guess the combination lcd monitor and led tv might had caused it.
duck130883
#3 Posted : Saturday, September 16, 2017 9:51:45 AM(UTC)
duck130883
Rank:: Member
Hello, I also have problems with this error. Call it as follows:
1. Insert some title / xml
2. Open the title editor
3. Save the preset "+" with very long text
4. Return to the Vmix base environment
5. Right click on the input title window
if you have a third monitor as a preview (fullscreen) and have a higher resolution than the other monitors, the dialog box appears on a fullscreen preview monitor
thank you
sinc747
#4 Posted : Saturday, September 16, 2017 6:00:22 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
@duck,
What number version of vMix are you using?
- Tom
duck130883
#5 Posted : Tuesday, September 19, 2017 5:33:36 AM(UTC)
duck130883
Rank:: Member
Now I do not know exactly. But any 16 versions.
Is it fixed in newer years?
I really enjoy this software and I like to test it. It's just a shame that I do not own a PRO version. But perhaps it will be money to buy.
Thank you
