cas
#1 Posted : Friday, September 15, 2017 2:40:36 AM(UTC)
cas
I am using an XML files bring in scores of matches, I also need to do the same for news. All fields work fine except getting the thumbnails as an images. Can anyone assist. You can use any XML file and try. These being pulled live just like an RSS feed.
#2 Posted : Friday, September 15, 2017 5:01:09 AM(UTC)
Rank:: Advanced Member
Was thanked: 999 time(s) in 827 post(s)
Images have to be referenced (link) to their source
from the help files :
If your title includes an image field, this can also be assigned to a data source.
The data source text data must be either a full URL or file path in order to load correctly.
For example
http://www.example.com/image.jpg
corporatejames
#3 Posted : Friday, September 15, 2017 5:12:17 AM(UTC)
corporatejames
You can use URL paths. eg http://yourwebsite.com/images/picture.png
as soon as you make a change or update the xml, the image will update in Vmix
cas
#4 Posted : Friday, September 15, 2017 5:31:45 AM(UTC)
cas
Thank these links lead to no where. Anyway the XML data am getting comes directly from a third party so I would not have the images stored on my local server. I just pull a link add it to data sources in VMIX add the xpath and good to go. Once this is done I have all other fields. Please try this link in your VMIX and see if it works.
http://feeds.bbci.co.uk/news/rss.xml?edition=int let me know what you use for Xpath.
#5 Posted : Friday, September 15, 2017 5:56:38 AM(UTC)
then you link to the images on the source server .
using an online xpath tester will help you to find the codes for the nodes/xpaths you want
#6 Posted : Friday, September 15, 2017 6:57:23 AM(UTC)
rss/channel/item[X]/media:thumbnail/@url
where x is the item from which you want the image
but wont work in datasources directly so you would need to use some codebehind in your title to acces it and display . no idea on how to get the item number, sorry
google was my friend
