JonnyNoblett
#1 Posted : Tuesday, September 12, 2017 4:53:10 AM(UTC)
JonnyNoblett
Hoping this is a simple fix and I am just missing something.
If I run one vMix instance on one laptop where I input a png with transparencies and set the input so that there is a transparent background it seems that if I then use that inout over NDI to the other laptop as an overly the transparency isn't carried over. Do I need to use a colour key for this to work?\
Jonny
brian078
#2 Posted : Tuesday, September 12, 2017 10:40:37 AM(UTC)
brian078
Hi Jonny,
I think you should set the Output Format to ARGB32 on the laptop with the transparent png.
Go to Settings -> Performance, tick Show Advanced Settings and set the Output Format to ARGB32.
I hope it works!
Brian
wilcoxk
#3 Posted : Wednesday, September 13, 2017 10:29:13 AM(UTC)
wilcoxk
Following...... I am also a bit worried about that warning that says "Don't do this unless vMix support tells you to." ...........
RandomStreamer
#4 Posted : Wednesday, September 13, 2017 5:44:50 PM(UTC)
RandomStreamer
They say there might be performance loss:
Alternative, set a green layer, replacing the transparency, and use colorkey on the other end..
Otherwise, if you insist NDI'ing alpha channel, you might have performance issues.
best,
RS.
