Hi I've just purchased and install Vmix 20 and on the 64bit version i'm getting this error Value of '0' is not valid for 'emSize'. 'emSize' should be greater than 0 and less than or equal to System.Single.Maxvalue. Parameter name; emSize Please help PF attached the following image(s):  Capture.PNG (8kb) downloaded 62 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked PF for this useful post.
I've uninstall vmix 20 and installed 19 same issue uninstall vmix 19 installed vmix 16. and it now works. reinstalled 19 issue came bac reinstalled 20 issue came back uninstalled and reinstalled 16 and 64 bit version works fine please help. because I need replay for 4 cameras PF attached the following image(s):  Capture.PNG (8kb) downloaded 48 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi, Please email us at info@vmix.com.au for further assistance. This error will only appear if vMix has been tampered with, such as through an unauthorised version. Regards, Martin vMix
