4 Pages123>»
#1 Posted : Wednesday, September 6, 2017 10:34:36 PM(UTC)
vMix 20 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
thanks 6 users thanked admin for this useful post.
ask on 9/6/2017(UTC), stigaard on 9/7/2017(UTC), Video Dave on 9/7/2017(UTC), DYosua on 9/7/2017(UTC), madness on 9/8/2017(UTC), bluesgeek on 9/14/2017(UTC)
niemi
#2 Posted : Thursday, September 7, 2017 12:40:31 AM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
It is here! Awesome.
We are looking forward to testing it and putting it to use.
I was expecting an IBC-timed release, but this is even better.
g-mo
#3 Posted : Thursday, September 7, 2017 1:00:59 AM(UTC)
g-mo
How soon before we get a tutorial on the NEWblueFX titling?
richardgatarski
#4 Posted : Thursday, September 7, 2017 5:30:00 AM(UTC)
richardgatarski
You have been a member since:: 2/18/2014(UTC)
First of all, thanks to the vMix team for releasing yet another new version packed with wonderful additions!
Regarding "Added support for controlling NewBlue Titler Live 3.0 via NDI", could you please clarify. NewBlue FX has a host of "Live" products, for examples
- Titler Live ($299, and only in version 2.), compatible with Wirecast (but not vMix)
- Titler Broadcast ($1499], compatible with "any switcher with NDI Inputs"
Am I right that it's the Broadcast edition that is required?
richardgatarski
#5 Posted : Thursday, September 7, 2017 6:56:13 AM(UTC)
richardgatarski
Possible bug, 20.26: Second recorder's log is saved in the same directory as the video file (not in the log subdirectory).
jet
#6 Posted : Thursday, September 7, 2017 8:17:45 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
Major bug in 20.0.0.26
Settings->Options:
Un-tick some of the Transition Display check boxes.
Restart vMix.
The un-checked transition buttons are gone as they should, but hitting at least Record and External buttons will bring them back..
SHMD
#7 Posted : Thursday, September 7, 2017 8:23:56 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Martin and team at vMix, thanks for adding support for Titler Live. I am running v3 of the broadcast version and you may have just saved me a graphics operator in our setup with the new integration. Going to do some testing today to see if we can roll it out at our next event in a couple weeks.
jet
#8 Posted : Thursday, September 7, 2017 8:57:17 AM(UTC)
jet
Another major bug: Arduino Micro -based Tally Lights are still not working, nor v19.54 or v20.26 of vMix. Have tested it with 3 different systems (Windows 8.1 and Windows 10).
spino wrote
"Hi Jan. I don't understand what's the problem. I didn't check Arduino Micro for tally lights but I checked both Arduino Uno and Arduino Mega and they work (I had some problems with Arduino Mega but Martin solved this problem). Why don't you use Arduino Uno for example? "
So your solution is just to sweep the bug under the carpet and pretend it does not exist?
Would't it be better to find it and fix it?
Working as it should on vMix 18.0.0.59
#9 Posted : Thursday, September 7, 2017 9:15:46 AM(UTC)
Hi Jet,
Rest assured we are not sweeping it under the rug. We have been unable to replicate the problem, as it working fine in our tests.
Please try testing it on a different machine, or if you have access another another arduino device, please try that to compare first.
Failing that I think it is best to drop us an email (info@vmix.com.au), as we will likely need to TeamViewer into your system to see what is happening first hand.
#10 Posted : Thursday, September 7, 2017 9:17:21 AM(UTC)
During IBC, NewBlue will be announcing a new range of editions at a lower price point that all support NDI.
Once it is released we can go into more detail.
madness on 9/8/2017(UTC), Harty on 9/9/2017(UTC)
jet
#11 Posted : Thursday, September 7, 2017 9:45:00 AM(UTC)
jet
admin wrote:
Hi Jet,
Ok, sounds good.
Just tested it with Arduino Leonardo -clone (Romeo V2 R3/DFRobot).
The results are: vMix 18 connects to the Leonardo board OK, but not connecting with vMix 19/20(?), so this is exactly the same thing happening with Arduino Micro.
Arduino UNO connects OK here with v18 and 19/20(?).
Could this whole issue be casuded by the .NET framework and data conflict with culture data? Example some values are stoerd/used in the wrong format?
All the Windows systems I have run vMix on uses Finnish language.
https://social.msdn.micr...-numbers?forum=vbgeneral
https://docs.microsoft.c...s/best-practices-strings
Kind regards,
Jan
Micro specs:
https://store.arduino.cc/arduino-micro
Leonardo specs:
https://store.arduino.cc...no-leonardo-with-headers
Leonardo clone specs:
https://www.dfrobot.com/wiki/index.php/Romeo_V2-All_in_one_Controller_(R3)_(SKU:DFR0225)
Uno specs:
https://store.arduino.cc/arduino-uno-rev3
pm
#12 Posted : Friday, September 8, 2017 9:20:48 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hello vMix Team
In vMix 19.0.0.49 there was a new feature added:
* NEW BETA VLC option under Add Input -> Stream
Is this feature declared as stable now in vMix 20?
Is the buffer value reflected to the VLC option ":network-caching" or is this vMix's own (additional) buffer? How is this handled between VLC and vMix?
Thanks for clarification!
Patrick
xaver
#13 Posted : Friday, September 8, 2017 9:40:16 AM(UTC)
xaver
TCP/IP Tally never shows "3"
in the help file:
Commands
TALLY
Event Supported: Yes
Example Request: TALLY\r\n
Example Response: TALLY OK 0123...\r\n
Description: Returns a comma delimited list of tally value where 0 = off, 1 = program, 2 = preview, 3 = program + preview.
The list is padded to the total number of inputs currently added to vMix and may have up to 1000 entries as a result.
(Maximum possible length = 9 + 1000 + 2 = 1011 bytes)
program+preview only sents 1
and no comma delimiter
Eduardo dudu
#14 Posted : Friday, September 8, 2017 11:17:22 AM(UTC)
Eduardo dudu
Feedback
Thanks,
Hola quise probar y me sale este mensaje a que se debe¡
el valor 0 no es valido para emsize
Joeboe
#15 Posted : Saturday, September 9, 2017 5:05:06 AM(UTC)
Joeboe
Try uninstalling all NDI apps, clean the registry of all NDI apps, clear TEMP folders, and do a fresh install of the ver.2.....maybe, just maybe some conflict is happening with the two versions during installation...If it is not broken, why break it....I never update until a full release is made...even then, I do not rush to update....
That's just me....
Harty
#16 Posted : Saturday, September 9, 2017 5:57:46 AM(UTC)
Harty
Was thanked: 10 time(s) in 7 post(s)
+1 for this! very interested in this topic!!!
dmitry_sdm
#17 Posted : Saturday, September 9, 2017 9:54:34 AM(UTC)
dmitry_sdm
Bug:
In 20 version i can't see A snd B channel buttons in Audio Mixer.
Buttons appears when i choose enable in device list, but not appears when i choose real device :(
AlanZ
#18 Posted : Saturday, September 9, 2017 6:51:32 PM(UTC)
AlanZ
20.0.0.27 keep crashing after a few minutes on my wife's Dell 2-in-one computer Inspiron 13 7000 (Basic HD)
It kept giving me a corrupted memory error.
I uninstalled and reinstalled... same issue.
So I went back to 20.0.0.21 (the previous build that I tried on that machine), and so far it's working.
I will do more testing, but we have a Zoom session with a woodturing club in the morning, so I need to get past that.
#19 Posted : Saturday, September 9, 2017 9:21:44 PM(UTC)
dmitry_sdm wrote:
Bug:
The buttons will now only appear if the bus is correctly enabled.
If you select an audio device that is already being used by a different audio output, that might be why it doesn't
appear as it is not actually being enabled. (So selecting the same speakers output for both Master and A or B won't work for example).
#20 Posted : Saturday, September 9, 2017 9:22:48 PM(UTC)
Can you please provide the full error message, and a screenshot if possible?
4 Pages123>»
