Yes, the TCP API is case sensitive by design. Tally is the only event supported at this time, you can submit a feature request for additional items you would like to subscribe to.
Martin vMix
Joined: 2/13/2017(UTC) Views messages in topic : 5 Location: Birmingham, AL
I was testing my live streaming in 20.0.0.21 tonight and noticed that it was only sending about 10% of the set bit rate.
I had it set as a custom RTMP to my Wowza Streaming Cloud account. 1500 Kbps 720p
But, both the status window and Wowza confirmed I was only sending about 100kbps out via RTMP.
I only had one streaming output going.
Thoughts?
Can you send us the latest streaming log? It will be located in C:\ProgramData\vMix\streaming Email to info@vmix.com.auThanks
Disregard. Rookie mistake. I was streaming black, which throttles down. Once I actually put some video in program, the speed came up. Thanks for the quick reply... sorry for the false alarm.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
vMix 20.0.0.22 with NDI 3.0 update , any time soon ?
Cheers,
PFBM
Thanks for this edition. Although I own more than 15 VMIX am still frustrated. What does the word multiple instances mean? There are those of us is using this software who really love it. But the reality is as I need to remove my 15 PC and get this to work with only 2 servers. When will see an update where more than one instance can be used on the same PC? Would really like to see this happen soon. PC has powerful GPU which should be able to handle this. Loving this version but still need more after spending this much on the same software.
cassaranks wrote:Thanks for this edition. Although I own more than 15 VMIX am still frustrated. What does the word multiple instances mean? There are those of us is using this software who really love it. But the reality is as I need to remove my 15 PC and get this to work with only 2 servers. When will see an update where more than one instance can be used on the same PC? Would really like to see this happen soon. PC has powerful GPU which should be able to handle this. Loving this version but still need more after spending this much on the same software. When Multi-instance is enabled, you can open multiple instances of vMix just by launching the program vMix64.exe in your programs folder. Are you having trouble with this?
Joined: 11/14/2012(UTC) Posts: 380  Location: Finland Thanks: 239 times Was thanked: 28 time(s) in 26 post(s)
jet wrote:admin wrote:jet wrote: Has the source of this Arduino Micro bug been found yet?
Kind regards, J
I haven't been able to replicate the bug unfortunately, it is possible you have an old Firmata on your device that no longer works since vMix 18 or so, updating that should solve the problem. Regards, Martin vMix Hi. I have compiled the latest firmata to Arduino Micro and it just not working with 19 nor 20. I recall that there was this same bug happening with v16 of vMix. In version 16.0.0.115 it was fixed and it worked since then with no problem up to vMix v18. In v19 it was not working any more. Could it be some kind of USB/COM port allocation or some kind on depency issue in vMix? Hi. Any new clue what is going on with Arduino Tally Lights, especially on Arduino Micro and other ATmega32U4 microcontroller based systems? Found this old topic wich might help figure out what is going on: http://www.electro-tech-online....-upload-problems.142098/And from Arduino Micro specs: "The Micro board is similar to the Arduino Leonardo in that the ATmega32U4 has built-in USB communication, eliminating the need for a secondary processor. This allows the Micro to appear to a connected computer as a mouse and keyboard, in addition to a virtual (CDC) serial / COM port." https://store.arduino.cc/arduino-microKind regards, Jan
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
jet wrote:jet wrote:admin wrote:jet wrote:Hi. Any new clue what is going on with Arduino Tally Lights, especially on Arduino Micro and other ATmega32U4 microcontroller based systems? Found this old topic wich might help figure out what is going on: http://www.electro-tech-online....-upload-problems.142098/And from Arduino Micro specs: "The Micro board is similar to the Arduino Leonardo in that the ATmega32U4 has built-in USB communication, eliminating the need for a secondary processor. This allows the Micro to appear to a connected computer as a mouse and keyboard, in addition to a virtual (CDC) serial / COM port." https://store.arduino.cc/arduino-microKind regards, Jan Hi Jan. I don't understand what's the problem. I didn't check Arduino Micro for tally lights but I checked both Arduino Uno and Arduino Mega and they work (I had some problems with Arduino Mega but Martin solved this problem). Why don't you use Arduino Uno for example?
admin wrote:Note: New features should not be submitted here, please use the Feature Requests forum instead.
Sorry guys, had to delete your posts as new features need to go into the correct forum.
vMix 2X Preview Update has been posted (20.0.0.24)http://cdn.vmix.com/download/vmix20preview.exe* Added support for X-keys XK-68 Jog/Shuttle controller * Fixed error message on DeckLink output after some time on heavily loaded systems * vMix will now automatically attempt to recreate recording folder if it has been deleted * Right click Properties menu added to NDI input with additional diagnostic information * 4K streaming presets added * Removed 32bit vMix shortcut from start menu on new installs to prevent it from being accidentally run in the future * Fixed a couple of bugs in vMix Call that may have caused problems during very long calls (6+ hours)
 7 users thanked admin for this useful post.
vMix 2X Preview (20.0.0.24)
with NDI 3.0 ?
Cheers,
PFBM
admin wrote:vMix 2X Preview Update has been posted (20.0.0.24)http://cdn.vmix.com/download/vmix20preview.exe* Added support for X-keys XK-68 Jog/Shuttle controller * Fixed error message on DeckLink output after some time on heavily loaded systems * vMix will now automatically attempt to recreate recording folder if it has been deleted * Right click Properties menu added to NDI input with additional diagnostic information * 4K streaming presets added * Removed 32bit vMix shortcut from start menu on new installs to prevent it from being accidentally run in the future * Fixed a couple of bugs in vMix Call that may have caused problems during very long calls (6+ hours) Does removing the 32bit vMix means that it won't work on 32bit OS? This is one of the serious edge vMix have over Wirecast.
It is only removed from the start menu on 64bit computers to prevent confusion. If you have a 32bit PC, it will still work fine.
NDI 3.0 is not ready for primetime yet, but rest assured we will add it when it is.
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
When vMix 2X will be available for production?
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
Bug on .24:
When editing Triggers on a source, if you at first have a trigger that uses all fields (ie. Function, Input, etc.), then you later Edit that trigger to something that doesn't use all the fields, the trigger wrongly displays the unused fields from the previous setting.
To recreate:
1) Add a trigger to a source * Use OnCompletion, Fade, Preview, Duration 500, Delay 0
2) Now edit that trigger. * Highlight the above trigger and click Edit * Change trigger to OnCompletion, Playlist/NextPlayListEntry * Click Edit
Trigger NextPlaylistEntry doesn't use an Input. But it it still displays it as Preview on the details of the trigger, leftover from the previous setting.
 1 user thanked roverradio for this useful post.
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Possible Bug in 20.0.0.24:
Full-Screen: When the 'on top' checkbox is ticked (for both display 1 & 2), the second full screen does not appear to stay on-top. However, the first full screen does seem to stay on top.
Config:
-- Display 1: Set to monitor 4, On-Top checked. [OK] -- Display 2: Set to monitor 1, On-Top checked. [Not staying on-top]
G.
Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
admin wrote:It is only removed from the start menu on 64bit computers to prevent confusion. If you have a 32bit PC, it will still work fine.
NDI 3.0 is not ready for primetime yet, but rest assured we will add it when it is. and when to expect the implementation of NDI 3.0 in VMIX
