Hardware Compatibility
Thunderbolt disconnect: How to recover?
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
If a thunderbolt cable is somehow disconnect during production, vMix wont recognize the capture card when it is reconnected. vMix needs to be completely shut down and opened again. This is of course far from ideal if it happens during production.
Is this something that be recreated by the vMix team, and potentially something that can be found a fix for?
It would also be useful to know from other users if this is also the case with the AJA IO 4K, and other laptops running on different thunderbolt firmware revisions / drivers.
We use this combination:
Asus GL502 Blackmagic Decklink 2 Duo Sonnet Echo Express SE I Thunderbolt 3
Thunderbolt driver version: 16.2.55.275 Firmware driver version: NVM 4.00 PD 1.07.06
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
Its happened to me a couple of times as well. Thankfully, those times were during setup. I now take extra care not to disconnect the TB cable during production. If there is a solution for this, it would be great.
Kelvin
Kelvin wrote:Its happened to me a couple of times as well. Thankfully, those times were during setup. I now take extra care not to disconnect the TB cable during production. If there is a solution for this, it would be great.
Kelvin Thanks Kelvin. Could you post your setup? Maybe also with firmware & driver versions.
Joined: 11/25/2015(UTC) Posts: 22  Location: US Thanks: 1 times Was thanked: 12 time(s) in 6 post(s)
When any of my Thunderbolt devices disconnect, lose power etc, the only way to reconnect them to vMix is to restart vMix. My guess, and I'm only guessing, is that when the software starts it does a scan for hardware and the reason you don't want to do that mid production is due to interfering with already established connections.
Eric Pratt wrote:When any of my Thunderbolt devices disconnect, lose power etc, the only way to reconnect them to vMix is to restart vMix. My guess, and I'm only guessing, is that when the software starts it does a scan for hardware and the reason you don't want to do that mid production is due to interfering with already established connections. If this is the case, being able to force a re-scan would be the solution. Maybe this could be an advanced option that could be activated in settings. Any thoughts from the team?
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4739 time(s) in 1626 post(s)
Due to how Thunderbolt and PCIE works, it is not possible to redetect the device in vMix without restarting the software. The best solution is to work out a way to secure the connector so it never becomes unplugged.
Martin vMix
As IceStream mentioned, this is a Windows issue most likely. Maybe a Windows 7 user can jump in because on that OS, some of the Apple forums state you have to reboot the computer. Starting with Windows 8/8.1 rebooting wasn't necessary.
@niemi
Is the situation your Thunderbolt cables are getting unplugged by accidental contact? For my AJA IO XT the Thunderbolt cables I use fit very firm from the IO XT to my laptop. It takes a fairly hard pull to get them out, so they wouldn't come out by getting bumped. Of course, someone could press the power switch on the IO XT.......
SportsNetUSA.net wrote:As IceStream mentioned, this is a Windows issue most likely. Maybe a Windows 7 user can jump in because on that OS, some of the Apple forums state you have to reboot the computer. Starting with Windows 8/8.1 rebooting wasn't necessary.
@niemi
Is the situation your Thunderbolt cables are getting unplugged by accidental contact? For my AJA IO XT the Thunderbolt cables I use fit very firm from the IO XT to my laptop. It takes a fairly hard pull to get them out, so they wouldn't come out by getting bumped. Of course, someone could press the power switch on the IO XT....... It was something I discovered when unplugging on purpose. I always secure the laptop end of the thunderbolt cable with a piece of duck tape. As you say it is pretty tight already, but not tight enough to leave it to chance. The other end of the cable is actually secured with a screw to the Sonnet enclosure. It would be nice if laptop manufacturers provided laptops with similar mounts. admin wrote:Due to how Thunderbolt and PCIE works, it is not possible to redetect the device in vMix without restarting the software. The best solution is to work out a way to secure the connector so it never becomes unplugged.
Martin vMix Restarting the software is not an option while streaming and recording, so if this is the case a secondary capture / output card (maybe connected via USB) might work out as a plan b.
