Vmix 19 Tiral activation problems
Hello, I would like to test Vmix unfortunately I can not activate the Tiral version. I get always ERROR product key has expired and Registration me goes to the nerves I would like VMIX 19 testing and then something
What can I do there?
Sorry for my English it's from Googel translator I'm from Germany
@ cool18
That error usually means that vMixTrial 60 day trial has already been downloaded on that PC, even if it was several versions ago.
The Probelm is, this PC has a Clean Windows 10.
Register the trial with a different email address
I already Vmix just does not want it. Have now already on 3 computer getester all say the same I have 10 email addresses tried
Did you download from the official vMix site?
Ok short update I have it just with Windows 10 in VirtualBox Tested activation went without problems My Win10 PC is not activated
New windows 10 install doesn't matter, it will know. Needs to be new hardware.
After using the trial your options are Buy it, use the free version, get new hardware and new trial afaik.
I needed two trial periods to find out if VMix was for me, and then ended up getting the Pro version.
