Joined: 10/5/2015(UTC) Posts: 47  Location: Norman, Oklahoma
My chroma key with Vmix is generally always perfect. However, I have been running into a problem with white or pink shirts... that my shoulders are always too bright. I use smooth high quality LED lighting... so its not like I have spot lights on me. The rest of the key is fine. But for some reason it does not like those colors. Any setting I could adjust? If I adjust the brightness of the camera it causes issues from skin tone to just looking too dark in general. Any ideas or advice would be greatly appreciated.
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
What camera are you using?
Did you check your zebra?
Thanks RS
