michaelrb
#1 Posted : Sunday, August 27, 2017 10:42:00 AM(UTC)
michaelrb
The audio button on certain inputs goes off automatically, or needs to be activated multiple times during a broadcast. For instance, I have a list of video clips as an input. I always want the audio to be on, but it will turn off.
You can see the green audio button is on with some audio inputs and not with others. I would like the audio to always be green on all inputs that always deal with audio. Any help? Thanks...Michael
michaelrb attached the following image(s):
#2 Posted : Sunday, August 27, 2017 1:18:01 PM(UTC)
@ michaelrb
What are the settings in "General" window of each Input (cog wheel -> General)?
The "Automatically mix audio" box, should be unticked for this, if ticked, it will also turn off the audio when the Input goes from Live "On Air" to Preview or "Off air".
michaelrb
#3 Posted : Sunday, August 27, 2017 3:30:40 PM(UTC)
michaelrb
Thanks for the info. Should this option also be unticked for vmix call?
#4 Posted : Sunday, August 27, 2017 7:21:47 PM(UTC)
@ michaelrb
Depends on "production" requirements.
If the box is not ticked, you have to manually control the audio of the Input, that is, turn it ON and/or OFF as necessary, which can be a pain if you are not prepared or aware of it.
