MrFreeze
#1 Posted : Tuesday, May 7, 2013 10:38:28 AM(UTC)
MrFreeze
Does anyone know if vidiu would work with Vmix,
From what I understand it would, but just want to confirm this.
http://www.teradek.com/pages/vidiu
Cheers
#2 Posted : Wednesday, May 8, 2013 2:04:47 AM(UTC)
How do you want to use the device with vMix?
The Vidiu is designed as a streaming hardware encoder for web sites like UStream.
So you could plug the HDMI output of your computer to the Vidiu to stream to the web that way.
It is not intended to be used as a capture device like the Teradek Cube, so you couldn't input the stream into vMix without a server running in between.
MrFreeze on 5/8/2013(UTC)
MrFreeze
#3 Posted : Wednesday, May 8, 2013 4:44:45 AM(UTC)
MrFreeze
I was hoping it could be used as a capture device, since its so cheap,
oh well
