Hardware Compatibility
ASRock B85M Pro4 + Intensity Shuttle USB 3.0?
Quick shot in the dark here.
I got a streaming rig with the ASRock B85M Pro4. Both of the PCI-E slots are occupied with GPU and Decklink Mini Recorder. Now i want to add a second camera, but got no more room for additional Mini Recorders. So maybe the Intensity Shuttle USB 3.0 can help me out, but i'm reading a lot of reports of it not being compatible with a lot of motherboards.
So, does anyone know if the Intensity Shuttle USB 3.0 will work with the ASRock B85M Pro4?
If not, what are alternatives for adding another capture card, short of replacing the motherboard with one carrying more PCI-E slots?
Thanks!
The USB3.0 Shuttle has been notoriously unreliable. It is not on the vMix approved device list.
Have a look at any one of several of the USB3.0 dongles. They will get you either one HDMI or SDI input. I'm partial to the Magewell brand as I'm a reseller for them, but there are others available as well.
- Tom
