Videoguy16x9
#1 Posted : Tuesday, August 22, 2017 9:16:20 PM(UTC)
Videoguy16x9
I really need to get the audio off the main system (monitor and mouse) during live sports productions. I had read about Behringer BCF2000 being used, and after trying to figure out how they talked to each other, found out I needed vMix Audio Mixer Pro software.
The little software patch does interact with the Behringer BCF2000, but in bizarre ways. Sliders only move on the hardware from extreme to extreme. Moving the software sliders in between has no effect. Also, when (the rare times) I can get the hardware controls to control the software sliders in vMix, the hardware sliders always slam down to the minimum within a few seconds, but the sound and virtual slider in vMix remains at the same level.
If any of you have an idea of how to get this http://www.shop.njastad....roduct&product_id=62
to work with this http://www.music-group.c...trollers/BCF2000/p/P0246
I would be extremely grateful.
Videoguy16x9
#2 Posted: : Wednesday, August 23, 2017 11:31:14 AM(UTC)
Videoguy16x9
Today I get to answer my own question and hopefully help someone else along the way.
Njastad has a patch that works a treat, everything is working perfectly now.
If any of you have the same frustration, it is because vMix switched from a linear fader to an exponential one.
With the patch, the Behringer BCF2000 and vMix Audio Mixer Pro are simply brilliant.
thanks 2 users thanked Videoguy16x9 for this useful post.
pba on 8/23/2017(UTC), David_in_Philly on 3/23/2018(UTC)
GSK
#3 Posted : Sunday, June 28, 2020 8:02:16 AM(UTC)
GSK
Argentina
Anyone has the patch for behringer bcf2000? Its very difficult to configure it.
Thank you in advance.
Regards.
