Lzrd
#1 Posted : Monday, August 21, 2017 1:34:39 PM(UTC)
Lzrd
Just want to make sure if I understand correctly: with DeckLink Duo 2 I can connect one input to my laptop with Thunderbolt 3 / PCIe Expansion Box and I can use it as 1 IN / 3 OUT, 2 IN / 2 OUT etc. card from vmix? Earlier it was only one task per card so now it's gone?
Sorry I'm little bit out-of-date for few years with this stuff :)
niemi
#2 Posted : Tuesday, August 22, 2017 3:34:41 AM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
All connections on the Decklink 2 Duo can be used as either input or output.
The psychical order on the connectors are:
REF, SDI 1, SDI 3, SDI 2, SDI 4.
In Desktop Video Setup you will have to set these up the first time you install the driver.
So yes, you should be able to do what you want with the a laptop and a TB3 expansion box. :)
