Once again thank you for all your hard work.
But I have to say I'm dissapointed the 2 new outputs for the Pro version do not escape to the outside world via SDI.
Is this a design decision or a hardware limitation?
I could desperately do with being able to have extra outputs via my BMD Quad 2 for hardware recording. Yes I know Vmix has in-built recorders but I do believe in having multiple back-ups and being able to send an NDI out via SDI would be a huge advanatge for several scenarios I often require.
How about it guy?
Cheers David
vMix has up to 4 outputs.
2 via SDI 2 via Graphics Card Output
= 4 outputs
Thanks: 16 times Was thanked: 81 time(s) in 72 post(s)
You could use NDI connect to send those outputs to a SDI output.
