Joined: 7/25/2017(UTC) Posts: 1 Location: Winchester, VA
I am new to vMix, being a Livestream customer for 2 years. I was wondering if there is an "aux" channel where it can be one of the screens and switch between videos or vmix call. We have it in Livestream and it is limited but handy.
I don't know what you mean by an AUX channel, but in Vmix you could add a playlist of videos and just switch back and forth as required. You could possibly even automate the switching with triggers or scripting if you didn't want to switch manually.
It sounds like you are referring to an External output. You can set External 2, to be any source you have available inside vMix. Definitely need more information on your workflow to know if that is what you're referring to.
Curtis
Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
It's high time you added at least one more alternative audio output. Now there is a possibility to output the master sound and headphones - it is necessary (I personally do not have enough to not carry a sound mixer with me) at least 2 more alternative outputs.
Rank:: Advanced Member
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Murchik wrote:It's high time you added at least one more alternative audio output. Now there is a possibility to output the master sound and headphones - it is necessary (I personally do not have enough to not carry a sound mixer with me) at least 2 more alternative outputs. It's late, and I am old and slow, so please help me understand. There are 4 outputs: Master, Headphone, Bus-A and Bus-B. Isn't that what you are looking for - or what am I missing?
