Data Source - multiple colums in one Textfield / Dynamic Textwidth
Hi, I'm trying to visualize a Lower third where the Complete Name and the Score should appear in one row, directly one after another. My Datasource is a XML-File where Firstname, Lastname and the Score are separated. So currently i have to create 3 Textfields, that get 3 separate Values assigned. ( See attached Image) I have no control of the length of the Names, so the 3 fields are split far from another to make sure even the longest names are displaed. Is it possible to combine multiple Columns in advance and assign the new "Textblock" to only one Textfield. For Example: Firstname: John Lastname: Doe Score: 33.000 becomes new Textblock: "John Doe - 33.000" which is assigned to one Textfield Or is there a Way to make the width of the Textfields dynamic, so that Textfield1 is adjusted to the total width of the Firstname, then the Textfield2 is positioned directly after it, etc. Thanks in advance slxxi attached the following image(s):  vmix-titles.jpg (76kb) downloaded 29 time(s).You cannot view/download attachments. Try to login or register.
Hi Just my opinion but personally when it comes to lists i prefer them column like , looks neater especially like a score lists when displayed i had the some problem when names didn't fit in a texblock and dind't like the standard way of cutting of part of the text like with dots etc but there is a trick that works nicely for the occasional text (name) that is a little longer than what woul normally fit wrap the textblock inside a viewbox in the xaml code , it makes adapt the font in size so the full name still fits inside the textblock for fixed length Code:
' example out one of my titles
<Viewbox StretchDirection="DownOnly" Width="487" HorizontalAlignment="Left" Margin="127,23.5,0,21.5" Height="70" >
<TextBlock x:Name="Handler" Text="" Foreground="#FFFFFDFD" FontFamily="Novecento sans wide DemiBold" FontSize="53.333" />
</Viewbox>
Thanks for the Workaround, but i really need it the way i described it. Everey Textfield has to the spezified font-size. The above image might be a little misleading. Its not going to be a scoreboard, but more a Resultlist on a Stadium LED-Billboard. In the End the complete image will be mapped to pieces of 10m each, so the combined Textfield that i want to have will be centered on a speficic tile. Any further hint is appreciated slxxi attached the following image(s):  stadium.jpg (57kb) downloaded 20 time(s).You cannot view/download attachments. Try to login or register.
Probably better of then creating a dedicated title with data binding and combining the data etc reading directly from the data file ( not through datasources) using Blend or Visual Studio, will need some coding though Googeling on XAML coding might be helpfull ex Concatenate strings instead of using a stack of TextBlocks
To add to doggy's suggestion:
Whenever I'm bringing in data from a google sheet/csv, I'll generally set up a cell that combines multiple cells with my preferred format and delimiter. This populates using the raw data cells, so it's still dynamic in that respect. If you have the ability to control how your XML is generated, I'd look into adding a value that combines the strings as you described.
Sadly the xml is provided by a 3rd party, so i can't really cotrol it. I'm now going tu use an "extenal Controller" that grabs the xml, combines the fields and sets the Textfield directly via the API. But thanks for your suggestions
