Groups: Joined: 8/8/2017(UTC) Posts: 9  Location: Brasil
SOCORRO: I need to set up recording in 16: 9. How do I do that? I already configured the input, everything goes in widscreen but the recording will not. What are you doing wrong?
Grateful, help me
sergio brasil
@ sergio figueiredo
What is the "Size" (resolution) and format in your Recording Settings? (cog wheel of Record button) Also, what are your General Output Settings for "Output Size" in "Display" and "External Output"? (Settings button upper right of UI)
hi, 720 x 480
But the output is widescreen or 16x9, only the recording is 4: 3. Already tried to put 1280 x 1024 but did not change anything. I work in SD 720 x 480.
sergio brasil
Try setting the outputs to 720x405.....you can do that in the external out/NDI
