Is it possible to split the audio to 2 separate channels? I tried but have not succeeded in splitting the two. I want 1 channel from left and left to be converted to channel 1 left and right and second channel from right and right to be converted to channel 2 left and right and to be able to control which one i use live.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Good question, so you want to have one input on two audio faders, one the left source and the other the right source being sent to Master L+R ?
I've been looking for a way to do the same but with 6 embedded sdi audio channels. You can mix them down to stereo but not split them off. A virtual input doesn't carry the audio.
The only way I can see is to bring the input in multiple times taking up hardware resources.
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
yo1984 wrote:Is it possible to split the audio to 2 separate channels? I tried but have not succeeded in splitting the two. I want 1 channel from left and left to be converted to channel 1 left and right and second channel from right and right to be converted to channel 2 left and right and to be able to control which one i use live.
On audio setting of this input change to separate mono. Quote: I've been looking for a way to do the same but with 6 embedded sdi audio channels. You can mix them down to stereo but not split them off. A virtual input doesn't carry the audio.
Add ndi only audio and uses the mixer
dark_ata wrote:yo1984 wrote:Is it possible to split the audio to 2 separate channels?
Tried that didnt work. It still mixed the two
sorry i don't understand what do you want to do
