3rd Party Software and Development
Possible to change multiview zoom, pan X, etc. for inputs via script?
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
Is it possible to change the Zoom and Pan X/Y for multiview on an input via scripting? By the docs I'm guessing I can change the source of the multiview inputs (which I also need to do), but don't see any documentation on changing, say, Pan X setting on Multiview 5 on Input 9.
The docs say "The following shortcut functions can be called either via a Shortcut or via the API. The list of functions is constantly growing so the functions below only represent a small fraction of what is available."
Is there a complete list of everything somewhere?
Thanks!
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ roverradio
AFAIK, if the documentation is not up to date, the most complete list will be within the latest vMix release's Shortcuts Edit window pop-up. However, as you mention, I don't think adjusting the parameters or the positioning of MultiView (multilayer) Overlays is possible yet. (perhaps a feature request is in order, if it has not already been requested). A workaround might be to set-up a Virtual Input, adjust zoom and Pan as desired and Merge between them. Just a thought.
Joined: 11/25/2019(UTC) Posts: 43  Location: Bordeaux Was thanked: 2 time(s) in 2 post(s)
Anybody knows if it's available now since it's been a few years?
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
I also look for that, to be able to manipulate the inputs that are in a multiview of an input, only by creating virtual inputs from them I can do it, of course so as not to touch the original ones Spanish translated from google
I am also interested in this functionality and a novice when it comes to scripting. Any help would be amazing!
