Add Program (External 1) to an input for use in a multi-box
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
I have the need to create a 6-up multiview and send it out via SDI. It consists of 5 cameras and the Program output (so people in Studio B can see all the cameras of Studio A along with the Program output).
I've gotten it to work by adding External 1 as an input via NDI (essentially sending NDI from vMix back to itself as an input). Is there a better way to get Program (external 1) available to to use in inputs without using NDI?
Hope that all makes sense.
Thanks!
@ roverradio
Which edition of vMix are you using? Is the "Fullscreen" MultiView output an available option for you?
19 Pro (now testing 20 as well).
Unfortunately I need to be able to customize what's shown and sizing/positioning a little more than the available fullscre3en multiview options.
Of course I could also take an output from our VideoHub and route PGM/Ext1 to an available SDI input (may be a little less resource intensive than using NDI, perhaps?)...was just wondering if there was a way I am missing.
it's probably not all that common a request I suppose, but as vMix adds more outputs and people have more complex needs for return feeds for vmxix calls, etc. I can see it becoming a little more common.
