sergio figueiredo
#1 Posted : Tuesday, August 8, 2017 7:26:36 AM(UTC)
sergio figueiredo
Groups: Guests
Hello, my name is Sergio Figueiredo and I am the Director of a
government television in Brazil, and we have several broadcasters in
Brazil.
I'm sending a suggestion so that Vmix is ??accessible to us.
First: the live broadcast for you tube and facebook should have separate
start because we can stop the transmission on facebook but continue on
youtube or vice versa.
This would help a lot, and now the start is simultaneous, that is, I
start or all at the same time and stop all at the same time and this is
not good.
Second: I've already said it once, I'm repeating.
Our newspapers need the CG (generator of characters) or titles, to be
made by another official (in another pc) and at the moment I can only
insert and edit texts on the same pc.
See example of the Tricaster (live text) and or NsCaster that has the
separated and integrated Cg. I would be very grateful if you would give
me credit, because our network of TV of the parliament makes live
transmissions and they need that the Titles be done and redone at all
times, and with the program in the air live it can not be done by a
single operator, you understand me?
Third: when adding the cameras it should have a WAVEFORM or vector scop
so that we can give luminance quality and colors in the added cameras.
Fourth: the Vmix output should also have NDI output.
Fifth: virtual set editor
Thank you
Sergio Figueiredo
Tv director of the Ribeirao Preto Parliament Brazil
https://www.facebook.com/redelegislativa/
https://www.youtube.com/...UCqQhCrYl2nXCmLGZ83zZ6yw
http://www.camararibeiraopreto.sp.gov.br/JW34/
Sergio Luis Figueiredo
Coordenadoria Tv/Rádio
Câmara Ribeirão Preto
16.36074004 /4072
#2 Posted : Tuesday, August 8, 2017 8:29:56 AM(UTC)
@ sergio figueiredo
First of all, welcome to the vMix forum!
You make a lot of interesting suggestions, some of which have been previously made by others.
It is always best to make singular requests in the "Feature Requests" thread so that they can spawn discussion and/or support individually for their own merit. It is also beneficial to do a search for similar requests to avoid duplication and dilution of the discussion.
(such as vectorscopes in this case: https://forums.vmix.com/....aspx?g=posts&t=6208 and multiStreaming options: https://forums.vmix.com/....aspx?g=posts&t=6165 )
Also, some of your titling requests are already possible depending on your workflow and specific requirements.
(you might be interested in exploring vMix UTC : https://forums.vmix.com/....aspx?g=posts&t=6165 )
Hope that helps some and welcome aboard.
