Shortcuts: How to end a Stream with a shortcut?
Joined: 6/17/2017(UTC) Posts: 6 Location: New Hampshire
Looking for a way to end a stream as a shortcut fired from tablet
@ adziebart
Set-up a Shortcut key to "StopStreaming". Access the "Web Controller" on your tablet. (address found at Settings -> Web Controller) All your "Shortcuts" should be displayed on the first page (4 white squares). If you only have the "One" Shortcut, you're good to go, if you have more, you'll need to locate the right one.
There was a request a while ago, if I remember correctly, to be able to "limit" how many and/or which buttons to allow on the Web Controller if you care to search and add your support there if that is something you need or desire. It also seems to me that someone developed a script or app to do just that, but I'd have to look into that further.
Hope that helps.
