tony marone
#1 Posted : Saturday, March 20, 2010 10:46:41 AM(UTC)
tony marone
Hi Martin,
I have been doing some tests with RC2 concerning the remote screen capture. It seems that a remote session that you set up dosen't get saved properly when you quit vMix. When you start next time then load the last session the remote capture window is there but blank. If you quit then you will get 3 errors of 'value cannot be null'. Please check this out and let me know if this is truly a bug or something i'm doing erong.
Thanks,
Tony
#2 Posted : Sunday, March 21, 2010 2:39:49 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
This is a known bug which will be fixed in the next release.
