vmix deneme sürümünü kurdum ancak vmix ile bağlantı kurmuyor "vmix not running" hatası veriyor. yardımcı olabilir misiniz? [img]h...[/img]
Start vMix, then vMix Social.
ask wrote:Start vMix, then vMix Social. Thanks for your reply, but I do it already. It is not I'm closing the firewall It is not
Are you trying on the same computer as vMix? It must be on the same computer
I run it on the same computer
I did not install it on another computer
@ enes vMix and vMix Social are two separate programs and need to be run simultaneously. If vMix Social does not detect vMix, you may need to "Enable" the "Web Controller" in vMix Settings (Settings -> Web Controller -> Enable) Also note that the Port should be 8088. Hope that helps some. A tutorial Video can be found here, if you haven't watched it already: http://www.vmix.com/products/vmix-social.aspx Ice
 Set it this way
(Not Running ) Merhaba Türkiye de aynı sorunu bende yaşamaktayım. bu konuda yetkili birisi lütfen yardım edebilir mi ? ürün demo değildir.
