cyoo
#1 Posted : Wednesday, August 2, 2017 4:17:15 AM(UTC)
cyoo
Hi there, how can u control size of the input box? i have 30 inputs and want to see all of them with small sizes. thanks.
Joeboe
#2 Posted : Wednesday, August 2, 2017 6:58:59 AM(UTC)
Joeboe
I do not think that is possible, ...the smallest size of those inputs is 208 x 156....maybe that could be a request....but you can make the preview and program windows smaller, but I still do not think you will be able to see 30 inputs all at the same time.
#3 Posted : Wednesday, August 2, 2017 8:44:52 AM(UTC)
@ cyoo
Joeboe is correct, the most Inputs you are likely to see at once is 24 with the smallest Input size currently available and the Program and Preview screens reduced to the upper third of the screen.
Input Size is chosen in "Settings -> Display"
Preview and Program are reduced by finding the divider on the main UI, click and slide up.
I believe it has been previously requested for smaller Input sizes, so if it is something you really need, I would suggest you add your support for such a feature there and maybe describe your need or reasoning as it may assist in garnering support.
Here is a link to the Feature Request:
https://forums.vmix.com/....aspx?g=posts&t=5829
Hope that helps some.
desmar
#4 Posted : Wednesday, August 2, 2017 9:42:59 AM(UTC)
desmar
Canada
Would be nice to be able to un-dock inputs like the Audio is capable.
Even perhaps 1 un-dock window for every input Category.
What would be good also is to combine Video with Audio.. with option to turn on/off
viewing audio next to input.
eg. Show video box with Audio next to it.
desmar attached the following image(s):
#5 Posted : Wednesday, August 2, 2017 10:38:43 AM(UTC)
@ desmar
Those are really interesting suggestions.
I would recommend placing your post in the "Feature Request" thread where it will potentially get more exposure and support than in the "General Discussion" section.
Just my thoughts.
mjgraves
#6 Posted : Wednesday, August 2, 2017 11:23:20 AM(UTC)
mjgraves
Why not simply connect a 4K monitor? That gives you vastly more real estate for UI items.
I tried connecting my desktop to a 50" 4K monitor for the first time recently. Windows defaulted to zooming everything to 300%, which was fine for working from a distance.
Zooming down to 200% seemed a nice compromise between a large canvas and legible text.
Zetor1980
#7 Posted : Wednesday, August 2, 2017 12:26:26 PM(UTC)
Zetor1980
hmmm, I don't think that I will use this option, sorry ;)
kjones9999
#8 Posted : Thursday, August 3, 2017 9:30:02 PM(UTC)
kjones9999
You can also minimize uneeded inputs.
boris9831
#9 Posted : Friday, August 4, 2017 10:06:04 PM(UTC)
boris9831
The input categories (file folder tabs at top of input list - right click) work great for this - I use one for each of 3 PTZoptics cameras with 10 virtual each then Videos, Graphics, Titles etc.
Similar Topics
Bug?: Saved PTZ virtual input doesn't work different input size (General Discussion)
Belarus KurtL 5/14/2020 4:45:35 PM(UTC)
Bug with Input Size (General Discussion)
by xaver 4/22/2017 4:43:03 PM(UTC)
Input Sizes and Partial Collapse (Feature Requests)
by Ed Tech 2/15/2016 9:17:11 AM(UTC)
more input size resolutions to choose from (Feature Requests)
by wwdv 1/16/2015 10:31:25 AM(UTC)
