Fullscreen output is reversed
Joined: 6/27/2017(UTC) Posts: 11 Location: Boulder, CO
I plugged in a second HDMI cable to my graphics card and have that going into a Blackmagic Ultrastudio Mini Recorder going to my Macbook Pro. The image the Blackmagic is showing is reversed. If I plug in a camera to the Blackmagic, it's normal. I couldn't find any setting in Windows (I'm normally a Mac guy w/ this new Windows build specifically for vMix) or in vMix. I'm pretty sure it's a graphics card thing, and not vMix since the desktop is also reversed, but thought I'd through it out here to see if you knew where I can look. Thanks!
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Is the Mirror box checked in the properties panel of the input?
Egriswold wrote:Is the Mirror box checked in the properties panel of the input? no - if I leave everything the same on my receiving machine, and just plug in an HDMI out from my camera, it's normal
Opeb vMix, >Settings >Performance: near to the bottom, you will see two option, 'Enable Flip Ex on Full Screen' and 'Enable Flip Ex on previews' Try unticking them and see if that will solve your problem....
What happens if you connect HDMI out of vMix system to a monitor or TV ? is fullscreen still flipped ?
I'm embarrassed to post the fix. There wasn't one. I was using Skype to preview what was coming in, and for some stupid reason, Skype's preview window is mirrored. Oh well :) Thanks for the suggestions. I went through all of them and of course, none of them worked :)
