Problem with switching videos
Hi! I'm trying to play some videos in the row, i mean when one video ends to begin next one automatically. But when one video ends it stops and the other does not begin! I made some adjustments in transitions but nothing happing! What am i doing Wrong?
Have you used the "List" input? Add videos to the "List" and they will play in sequence whenever that input is active. Additionally, if you are transitioning from one input to the next, make sure your settings are correct for each video input ('i' button) Automatically mix audio Automatically Play with Transition Automatically Restart with Transition Automatically Pause after Transition
Thank you for your answer. When I make a playlist the videos play in sequence with no problem. But this is not what I want. I want just to add 2 videos and to play one after the other without making a playlist. Is that possible? Also the settings you mentioned are correct.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
vMix is not a traditional video playback application as such, so simply adding multiple videos in the input list will not cause them to play one by one.
The idea of vMix is to have multiple inputs of various types and then use the transition/cut/quickplay buttons to transition to them as required. If you want to automate this you can use the PlayList feature to add the two videos and then click Start so they play one after the other.
You can also use the "List" input type which allows adding multiple videos as a single input.
Martin vMix
