Feature Requests
Tally Light support for PTZ inputs
Joined: 12/16/2015(UTC) Posts: 33 Location: Philadelphia
Thanks: 6 times Was thanked: 11 time(s) in 7 post(s)
I just setup some Tally Lights from Tally Lights LLC. I can't believe how easy it was!
The only thing I noticed is that the PTZ Preset Inputs do not seem to work. Only the orginal camera inputs.
It would be nice to have the PTZ Preset inputs link to the master camera so that Tally Lights will work. I couldn't imagine users wanting to have separate tally lights for each input.
I found a workaround (thank you Martin).
If anyone is using a PTZ camera position (made from the original PTZ camera input) and you are using Tally Lights.
You can manually assign the master camera input to each preset under MultiView then untick the box so it is invisible. This will cause the tally for that camera to show when it is being switched.
Feature Requests
