Replay events greater than 999 can not be played or controlled etc through the API.
These events do work inside of vMix itself, but calling the API to play events greater than 999 doesn't play anything. I understand that this is due to some users having shortcuts to input using the keypad, so 001009 would play 1 then 9, so 999 is the max.
If a option to allow events greater than 999 was added this could satisfy high replay event number users and those that want to keep using 3 digit shortcuts.
