michaelrb
#1 Posted : Wednesday, July 26, 2017 7:23:51 PM(UTC)
michaelrb
I want to import only the audio portion of a skype call. I have created a virtual cable as an output for Skype which goes to an input on vmix. Works pretty well with the exception of an occasional audio pop. My problem is I want the caller to hear other inputs from vmix. The phone part of SKYPE is fine, but if I play a video or audio file from VMix, the audio is not heard by the caller. Is there a way for me to have the Skype caller hear other inputs from VMix?
I intend to use VMIX Call for those who want to join with both audio and video. I run a talk show and need a solution for anyone to call me.
Thanks............Michael
#2 Posted : Wednesday, July 26, 2017 8:02:18 PM(UTC)
@ michaelrb
You'll need to go into Skype's Audio settings and set your "microphone" to be able to acquire vMix's Audio Output. This may require some virtual cabling as well if the option is not readily visible in Skype.
This step by step instruction from a few years ago is probably the best reference on how to do it:
https://forums.vmix.com/...ts&m=11167#post11167
Hope that helps some.
