Adjusting line spacing in a paragraph of title text
When the title text is wrapped into multiple rows, the default space between lines is very narrow. Is there a way to adjust the line spacing either using the general user interface or via API?
Thanks in advance.
@ puruzio
Which "Title" are you using? I think a lot depends on the Font style and Size of text you are using. AFAIK, there is no adjustment within vMix or the TitleDesigner to adjust or set the line spacing (this may even be from a default setting in Windows for things like 'Read Me' text files IDK). Have you tried different Fonts and or Sizes?
You have been a member since:: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 797 time(s) in 591 post(s)
Hi
A workaround is to create one text area for each line. This way you can define precisely line spacing.
Guillaume
