Gary-WSN
#1 Posted : Wednesday, July 19, 2017 4:30:26 PM(UTC)
Gary-WSN
Okay, all you smart people out there, I need some help.
I've created shortcuts for our scoreboard XAML to include timeouts by having certain keystrokes "SET TEXT" in a title to 0 dashes for no timeouts remaining, 1 dash for 1 timeout, etc. This means for football, I have 8 keys designated for timeouts (0, 1, 2, 3 timeouts per team). And when we get to basketball, that expands up to 12 keys (0-5 timesouts per team).
What I'm hoping to do is have a shortcut that TOGGLES up and down +1 or -1 like I do for score (I even have a +3 for FG and +6 for TD key). Values are a cinch. Text such as a dash or other symbol, not so much.
I'm including pics of my current X-keys setup and a scoreboard XAML screenshot.
Thanks in advance for any help.
Gary-WSN attached the following image(s):
Screen Shot 2017-07-17 at 10.24.20 AM.png (108kb) downloaded 2 time(s).
#2 Posted : Wednesday, July 19, 2017 5:23:37 PM(UTC)
Hi
in vMix you can create a shortcut that will trigger a +=1 3 times or 6 times in a row to get what you want
Check this : http://www.vmix.com/know...n-vmix-with-the-keyboard
However I would suggest you drop an eye on vMixUTC which has native functions for managing titles and scores in vMix
https://forums.vmix.com/....aspx?g=posts&t=6468
A demo video of vMixUTC for ice hockey
Hope this helps
Guillaume
Gary-WSN
#3 Posted : Friday, July 21, 2017 2:47:58 PM(UTC)
Gary-WSN
Thanks, Gullaume.
Wasn't able to find what I'm looking for there. I already use the +=1 and -=1 functions for score and other digits. The problem I'm having is trying to use the same idea with a SYMBOL like a dash or asterisk to indicate timeouts. I could always make the timeout indicators a digit, but for asthetics, want them as dashes.
Is there a way to increase "-" to "- -" and then "- - -" etc. each time I hit ONE button? or delete a dash each time by hitting just ONE button? I'm currently using 4 buttons per team for timeouts and this is taking up valuable space on my X-keys. Trying to consolidate. Once we go to basketball season, it will only increase the number of keys needed.
Ideas anyone? Is this even possible?
kjones9999
#4 Posted : Friday, July 21, 2017 5:27:02 PM(UTC)
kjones9999
There is probably another way to do it, But I would make an image with 1 bar, a 2nd with 2 bars etc -- Then use a shortcut to call them.
#5 Posted : Friday, July 21, 2017 6:14:20 PM(UTC)
I do this with vMixUTC from a single dropdown (List Button).
Check this demo video I did for UTC - the example is close to yours: when a player or several players are sent to jail in ice hockey
kjones9999 on 7/21/2017(UTC)
