Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Hi guys I wonder if someone knows the answer to this. I have a graphic lower 3rd I'm overlaying with overlay 2. I've used a trigger to overlay a standard text preset over the top on overlay 3. It works fine on the in but on the out it wont trigger the text layer to come off until the overlay 2 lower 3rd has completed it's transition. Is there any way to trigger overlay 2 and 3 to 'overly off' simultaneously? File Attachment(s):  lower third trigger.avi (3,267kb) downloaded 13 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi
did you try with OverlayInputAllOff ?
Guillaume
DWAM wrote:Hi
Guillaume
Guillaume, thank you for the reply and suggestion. It didn't work but it did make me rethink the operation, simply swapping the trigger command to the text overlay to then trigger the lower 3rd fixed it. So thank you for making my brain work correctly :)
