Embedded ATEM Tally Data from vMix
I have a question someone may have the answer for. I am looking at using the Blackmagic ATEM Camera converters matched with the ATEM Studio Converters. I know using an ATEM switcher you get the tally to the unit from the embedded data on the program return feed, but I was wondering if there is a way to embed (if it isn't happening already) into the program SDI feed from vMIX so these units get tally.
if anyone has any incite or ideas that would be great.
Curtis
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
This lets you control the cameras CCU, whether it allows tally control you would need to ask on the BMD forums. vMix sdi program and parallel tally data could feed into this. It would require some programming. Blackmagic 3G-SDI Arduino Shield Now you can control Blackmagic Design cameras by inserting control commands into the SDI feed from an Arduino!https://www.blackmagicde...studiocamera4k/techspecsHow do you like the studio cameras ?
