DennisHansen
#1 Posted : Saturday, July 8, 2017 7:58:53 AM(UTC)
DennisHansen
Hello.
I am a new user of Vmix.
I use it as an background graphic when i DJ.
But nu problem is that i have 40 videoes but it seems like it's only the first 32 clips that loops, the rest 8 is just stopping at the end of the clip.
And the loop Button is on.
Amy suggestion?
Thank you! 😊
#2 Posted : Saturday, July 8, 2017 8:30:23 AM(UTC)
Hi
could you explain how you're using these videos? All at the same time ? In a playlist ? As a list ?
Guillaume
DennisHansen
#3 Posted : Saturday, July 8, 2017 9:14:08 AM(UTC)
DennisHansen
At the same time, in different categorys.
1 file playing at the time, but i have all of them "open"
I Hope you understand 😊
#4 Posted : Saturday, July 8, 2017 9:27:32 AM(UTC)
ok, so you have 40 videos inputs in your project and you're playing them manually one by one with the loop option, right ?
Is it always the same 8 videos that won't play in loop? Or any video after the first 32?
What happens if you add ONLY one of these 8 video inputs in an empty vMix project? Will it play in loop or not ?
DennisHansen
#5 Posted : Monday, July 17, 2017 7:13:12 PM(UTC)
DennisHansen
Sorry for Late response.
I have just checked and it seems to be all the Avi. Files that won't loop, while the mp4. Is loop able.
Do i have to convert the files or is there a setting for that?
Thank you!😊
#6 Posted : Monday, July 17, 2017 8:57:06 PM(UTC)
@ DennisHansen
It shouldn't matter what file type, as long as the GREEN Loop Button is active...
If there is a problem with the file itself in terms of how vMix sees and plays it, in this case, perhaps it's not playing right through to the end for some reason (I've had videos that stall and freeze, always at the same spot, not exactly sure why, but I assume it hits a corrupt or unreadable part of the file). If that is the case here, I would recommend re-rendering the file if possible or converting it to another format to see if that "cures" the problem.
Alternatively, you could try to change the "Mark Out" point to a few frames or seconds from the end to see if that makes a difference.
