NDI
NDI PTZ camera and converters
what kind of mounting option does Connect Spark provide? I hope it can be mounted on camera top for Tally usage.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
Only way to do NDI through wireless is with 6x 300 mbps devices on 3 separate channels with 2 Bonding router/switch.
So
1 Bonding router/switch and 3x 300 mbps for receive and 1 Bonding router/switch and 3x 300 mbps for send. until NDI HX is out.
or
1x 1 Gbps for receive and 1x 1 Gbps for send with no Bonding router/switch.
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
 1 user thanked r@wisla for this useful post.
Hi Kane, Do you know if NDI3.0 SDK for Linux will be available as well? Many thanks!!!
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
rkay wrote:Hi Kane, Do you know if NDI3.0 SDK for Linux will be available as well? Many thanks!!! I would assume so. Kane Peterson NewTek
 1 user thanked kane for this useful post.
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
desmar wrote:Only way to do NDI through wireless is with 6x 300 mbps devices on 3 separate channels with 2 Bonding router/switch.
So
or
So that means 19.99$ in recycle bin! Will be more use friendly and cheaper an HDMI/SDI wireless trasmission system like Paralinx Triton.. I hope that NDI 3.0 will be available in the app soon as possible!
 2 users thanked kane for this useful post.
ask on 7/15/2017(UTC), DWAM on 7/15/2017(UTC)
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
So as I understand right:
Using the ethernet connector, Spark is only a converter from HDMI/SDI to NDI HX?
pm wrote:So as I understand right:
Using the ethernet connector, Spark is only a converter from HDMI/SDI to NDI HX? It is a converter from baseband to NDI-HX, a recorder and tally light. Kane Peterson NewTek
NDI
