Clocksmith
#1 Posted : Friday, July 14, 2017 7:30:31 AM(UTC)
Clocksmith
Hi All,
I'm sending vMix output to 'External 2' to feed some large screens at the British Grand Prix this weekend. I want to be able to send individual inputs to that feed while not affecting the main program output.
I was hoping to just select the source for External 2 in the settings popup next to the External button. It doesn't want to change though. It just sticks on main output as the source.
Any help appreciated.
Thanks.
#2 Posted : Friday, July 14, 2017 9:14:26 AM(UTC)
Hi !
Check SetOutputExternal2 command
In this post I explain how to use vMixUTC as an independent switcher for External2
https://forums.vmix.com/default.aspx?g=posts&m=34998#post34998
In this one, I demonstrate the same thing but using a Midi Controller
https://forums.vmix.com/default.aspx?g=posts&t=9765
In all cases, I'm using the same command. You can make shortcuts too for sure
Guillaume
Clocksmith on 7/15/2017(UTC)
