Jon Hart
#1 Posted : Tuesday, July 11, 2017 9:26:12 AM(UTC)
Jon Hart
Is it possible for multiple operators to operate Vmix at the same time? Like have a person dedicated to graphics, audio, replay, a TD etc?
mburel1980
#2 Posted : Tuesday, July 11, 2017 9:37:12 AM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
Jon Hart
#3 Posted : Tuesday, July 11, 2017 9:54:09 AM(UTC)
Jon Hart
Thanks for the reply. I read through that, and scrubbed through the video. Didn't see anything about having separate operators on the same machine.
Now I suppose I could run graphics through Caspar cg and NDI into the vmix computer, and then a separate external audio mixer, and I could use some DAs and feed a second instance of Vmix all my audio feeds. Just seems like a lot of work.
Actually, can you run multiple instances of the vmix mobile control software? Maybe I can use multiple tablets to achieve what I'm looking for.
#4 Posted : Tuesday, July 11, 2017 9:59:00 AM(UTC)
@ Jon Hart
vMix is a production tool that can be adapted to multiple types of workflows from the "one man show" to a full blown "TV Crew production", although each scenario will require specific or customized set-up protocols to accommodate a particular workflow configuration, which may or may not meet your expectations.
But a direct answer to your question is:
YES, it is possible!
mjgraves
#5 Posted : Tuesday, July 11, 2017 10:36:37 AM(UTC)
mjgraves
The availability of the API, and external control schemes that leverage it, implies that it can certainly be used in a multi-operator arrangement. However, such a setup may not be readily available, off-the shelf. It may require some DIY.
Digitalson
#6 Posted : Friday, July 14, 2017 1:29:57 AM(UTC)
Digitalson
Groups:
I developed an iPad app for different people can run different things....also I read in the forums that there is a software that can use 2 or 4 mice on a single computer,so if u can get 3 monitors out each person can have a window open that won't conflict with the other mice and keyboards on same system
