RandomStreamer
#1 Posted : Thursday, July 13, 2017 1:20:29 AM(UTC)
RandomStreamer
Believe you're in the wrong section
However, here's how you can do that
Create 2 triggers on your countdown scene
1. On transition in startCountdown (and select your timer xaml)
2. On transition out stopCountdown
Best,
RS
Joeboe
#2 Posted : Thursday, July 13, 2017 3:54:21 AM(UTC)
Joeboe
yup, I posted in the wrong place...gotta ty to move it
#3 Posted : Thursday, July 13, 2017 3:55:30 AM(UTC)
Alternatively you can use vMix UTC to do this
vMix UTC is here https://forums.vmix.com/....aspx?g=posts&t=6468
I give examples here including on how to work with timers : https://forums.vmix.com/....aspx?g=posts&t=9393
Joeboe
#4 Posted : Thursday, July 13, 2017 4:36:47 AM(UTC)
Joeboe
Thanks, I got your score bug to work......got to try to trigger the timer in vMix to work as well
UPDATE: Seem to have things working .....all scoreboards synced, eveything working ok...
