Hardware Compatibility
help with my video capture AV4000B
does not capture pci804hv_ver. 1.0
How about Ulysses is a DVR card that I use cards like this but not reconose Vmix firsthand, you have to change the card driver, this can be done by first installing the "Active web cam v 9.9" no matter if is trial and run it, it comes out and give options where it says looking cameras and start looking for your credit card and so is what you have to say if your pal or ntsc sitema and you install the appropriate drivers and recognizes and vMix . I hope this helps you work for me either.
